This week's word : smoke stack
ChrisJ
Member Posts: 16,906
So.
Where did the term smoke stack come from and why? This of course also lead to the term "stack effect" as well.
Is it because we stack pipes? Is it because the smoke stacks in the pipe?
Hmmm.
Hmmm.
Kind of strange that they were originally called stalks and that a cluster of stalks was called a stack. Maybe stack is easier to understand when spoken than stalk. Also, men like to say stacked; or, used to.
Thanks for the history lesson, @DJD775!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I don't know if this totally clears it up but interesting nonetheless.
https://smithheritagesurveyors.com/a-brief-history-of-chimneys-chimney-stacks-and-chimneys-pots/#:~:text=In Middle English it was,superstructure of the stack, i.e..1 -
I usually think of a stack as a metal chimney, but plenty of people call masonry chimneys stacks.
It's almost like residential is a chimney and commercial/industrial is a stack.
Same with ships " the stack is smoking" they would never say the chimney is smoking.0 -
EBEBRATT-Ed said:I usually think of a stack as a metal chimney, but plenty of people call masonry chimneys stacks. It's almost like residential is a chimney and commercial/industrial is a stack. Same with ships " the stack is smoking" they would never say the chimney is smoking.
We also have plumbing. Drain stacks etc.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
