Cast Iron sealed combustion boiler
Le John
Member Posts: 248
Good afternoon all - Weil McClain used to make a CGA that was a sealed combustion boiler but I don't see that on their web site any longer. Did they stop making that model? I need something small around 40 to 50K to go into a first floor closet. I thought about the smallest Lochinvar Knight but running a condensate drain is a problem. Anyone know of a sealed combustion unit?
X-PV - US Boiler / Burnham or Crown Bali 2
There are likely other variants of this design. I was looking into these but with additional direct vent kit and other factors, my contractor informed me that the cost is higher than a Lochinvar Knight.Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.1 -
If you can get the vent out for a mod con you can get tubing from a condensate pump out. They are reliable if installed properly.0
It would be better to get it to a laundry tub or a floor drain or a tee in a trap under a sink but there are ways to make the outdoor part drain so it doesn't freeze.
What kind of emitters do you have, what swt do they require, will it be condensing much?0 -
Base Board with water temperatures between 150-170mattmia2 said:It would be better to get it to a laundry tub or a floor drain or a tee in a trap under a sink but there are ways to make the outdoor part drain so it doesn't freeze.
Unless it is adequate at much lower temps in milder outdoor temps that is going to produce very little condensate.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 115 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
