Viessmann Vitodens 100 WB1B-35 Burner Screws
Steve_166
Member Posts: 11
Was wondering if anyone new exactly what size the four torx screws that hold the burner on are. I know the manual says they are Torx T-30 but not sure of the thread or length. Viessmann does not have a part number nor any further info. My local rep gave me a bag that he got at Blowe's but I don't have confidence in the quality (would really be a pisser to have them snap off). The screws he gave me are Metric M6-1.00 x 12 stainless steel Philips head bolts. He told me to try them, he believes they should work. I found some online with Torx T30 heads that are Marine Stainless A4-80 grade but would like to make sure I have the right size before I order them.
Two btu per sq ft for degree difference for a slab1 -
You can buy a whole kit of stainless metric bolts of any head configuration on Amazon for not much$$Bob "hot rod" Rohr
Living the hydronic dream1 -
Appreciate all the input. They are the screws that hold the burner door/plate to the heat exchanger. Every other year I do more than just check parameters on the exhaust (I call that a Level 1 Cleaning) for customers and actually pull it apart and clean the heat exchanger (Level 2 Cleaning). Over the years those Torx screw heads start to feel like they are wearing out. Want to change them before I have an issue. Now that I have some, I will check to see if they fit and order the stronger ones to actually install. Was just hoping someone had replaced these and knew the size so I can install the stronger ones the 1st time.0
We've done quite a few of the warranty heat exchanger replacements (model B2HB) and they provide replacement screws that we save and would be happy to send you some if you need them. I believe they are the same as on your WB1B. Just PM me your address.
They often spall when removing or installing and we replace with Locktite Anti-Sieze on the threads.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
- 50 Industry Classes
