oil tank bulge
mya
Member Posts: 1
in Oil Heating
How do you know if your oil tank is bunded.
There is no easy way to check for a buldge tank. The tanks are elipitcial so hard to come up with a good circumference measurement. Can visually keep an eye on it looking for spider cracks in the paint. Go and watch the take while they are filling it. Its sort of scary how much it moves around. Keep an eye for some irregular bows in the tank wall.
Steve0 -
Do you mean bunded in that it is a double wall or bulged? Bulge means it's been over pressurized.mya said:How do you know if your oil tank is bunded.
bulging will usually be shown on the ends of the tank which is the weakiest part.0
What do you guys mean " bulging " ??
@Big Ed_4 damage from overfilling and pressurizing the tank is what I am think although maybe the op has something else in mind.0
- 120 Geothermal
