Honeywell Unique Valves
Does anyone where I can purchase a Honeywell Unique Valve
    mattmia2 Member Posts: 16,043
    Danfoss and a few others make a valve with a lance you could probably retrofit.
  • nokindaplumber
    nokindaplumber Member Posts: 6
    As this valve received a recent resurrection via the mailroom@heatinghelp.com I thought this might be of interest to others who still have a functioning Unique valve.
    Wish I knew where the last remaining stock of these were hiding.
    EBEBRATT-Ed Member Posts: 19,908
    Probably long gone
    there might be some in like a barn or abandoned commercial building somewhere but the chances of them getting united with someone that knows what they are is pretty close to 0. you'd have a better chance of salvaging them from a building that is being torn down or "modernized". danfoss and a couple others make a valve with a lance that could be used in a similar way. modern valves won't allow for the series loop bypass thing.
    the honeywell book is in the library on here somewhere.
  • Grallert
    Grallert Member Posts: 1,076
    Oventrop makes or made a single entry radiator valve. I've used them to convert cast radiators where holes where floor penetration was limited.
  • 8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
    mattmia2GGross
