Triangle Tube Prestige heat exchanger corrosion
Oh—and I should add that there are bluish white plastic particles in the kitchen and bathroom aerators. That made one plumber wonder whether the tank has a pvc pipe for cold water that is deteriorating.0
I talked more to the plumber yesterday and researched the soot that we might have. Magnesium or zinc anodes could cause the black soot. I can’t find if the Triangle Tube PE 110 has an anode in its tank. Has anyone actually worked on one and opened it up to see? That might determine if I pay to repair the system or replace it. 10 years for a boiler doesn’t seem long enough.0
To be clear, an ANODE ROD would be in your indirect water tank--if the mfg. designed it with one. It is NOT in the boiler. If your tank was designed with one...it may still be in there, or not. It is sacrificial. That is its purpose, If gone, it should be replaced.0
HeatFlo is the only stainless indirect that I know with an anode rod. Mostly they are in glass lined steel tanks.Bob "hot rod" Rohr
Hi, Sometimes the black "soot"you find in the water comes from deteriorating black rubber inside of braided flex connectors, like live on top of water heaters. The white, tan or blue plastic bits can be from a failing dip tube. Have a close look at the bits and see if they are all the same thickness, but have a slight curve to them. This would indicate bad dip tube.
Yours, Larry1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
