Spy Glass leaking
I just noticed a steady stream from my spy glass. It’s about 5 years old. Then entire system. It’s rust around the bolts. I immediately cut the boiler off. Is it safe to have on until I get someone out here?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Shut off the two valves on the gauge glass assembly for now and have your gauge glass replaced . Ok to run
