Beckett burner ID help
appears to be model AF. but the AFG also used that same housing. Th UL label is no help because that is the same lable for all the AF models. the rest of the model number will be based on the nozzle assembly and air tube length that is connected to it, along with the F head number.
What do you need to know the model number for?
So you need a replacement part?
This manual will have all the information you need for that burner.
https://5476519.fs1.hubspotusercontent-na1.net/hubfs/5476519/Beckett Products/AF-AFG Oil and Renewable Fuels Burner - 0.40 to 3.00 GPH - AC Power/6104-AF-AFG-Burner_Manual_092120.pdf?__hstc=&__hssc=
The actual burner air tube and assembly will complete the model number
The MODEL 40 sticker is not a Beckett number. That number was probably placed on the burner by the OEM manufacturer to identify what burner was to go on a particular size boiler of furnace.Edward Young Retired
Looks like it went under water.
Thank you for the quick reply, and the knowledge. I believe it is an AF. It’s attached to a very old boiler, and as i understand AFGs are not common on old systems. The reason i wanted to know the specific model was to determine if the Z gauge would work to set the electrodes and the nozzle distance. Also would be nice to know if i ever need parts.EdTheHeaterMan said:appears to be model AF. but the AFG also used that same housing. Th UL label is no help because that is the same lable for all the AF models. the rest of the model number will be based on the nozzle assembly and air tube length that is connected to it, along with the F head number. What do you need to know the model number for? So you need a replacement part?0 -
Page 5 of that manual has some of the model numbers based on the connected air tube
For example if you burner is an AF model and has a F3 head and a 6-5/8" air tube the full model number would be AF65XN
The OEM model numbers and specifications can be found in this booklet
https://web.archive.org/web/20221016094203/https://www.beckettcorp.com/wp-content/uploads/6711-OEM-Residential-Oil-Spec-Guide.pdf. If that burner is on an old Bock Water heater model number 40E the complete model number would be AF56YH
Is there a sticker on the left side of the housing by the nozzle line?0
the Z gauge is the correct dimension for assembly position on all F head burners.starter_hart79 said:
The Z dimension is different on L and V head air tubes and is nt measured from the face of the nozzle but from the face of the retention HEAD (with the slots)
I always kept a paper copy of this book on my truck, but you guys/gals have these digital things at your fingertips today. Good reference for other burners out there.
@starter_hart79 , it's probably an AF, but we'd need to see the head to be sure. A long time ago, Beckett made a model A using the same chassis but with a non-flame-retention head. Once in a great while we run into one. There should be a label on the left side of the chassis near where the nozzle line is connected that will show the model.
If the head looks like this:
https://www.supplyhouse.com/Beckett-F6-F6-Replacement-Burner-Head-for-AF-AFG-SR-Series
and it has a 3450-RPM motor, then it's an AF.All Steamed Up, Inc.
Consulting1 -
I’ll have it apart tomorrow to replace the nozzle. I’ll take some pics of the head, and look for the label. Thanks for all the knowledge. Researching these online got very frustrating.Steamhead said:@starter_hart79 , it's probably an AF, but we'd need to see the head to be sure. A long time ago, Beckett made a model A using the same chassis but with a non-flame-retention head. Once in a great while we run into one. There should be a label on the left side of the chassis near where the nozzle line is connected that will show the model. If the head looks like this: https://www.supplyhouse.com/Beckett-F6-F6-Replacement-Burner-Head-for-AF-AFG-SR-Series and it has a 3450-RPM motor, then it's an AF.0 -
You can tell by the fan. The AFG has more vanes. It also has a fan shroud whereas the AF does not.0
- 120 Geothermal
