Honeywell "Home" V8043E zone valve blow-out
psb75
Member Posts: 1,126
Has anyone had experience with this Honeywell zone valve blow out its O-ring?
I am attending to major boiler room damage due to water spraying out of a failed zone valve O-ring. The house was not occupied for a while...so a lot of water sprayed out.
I did not see the failed valve before it was replaced. I'm being asked to replace O-rings on 5 more zone valves. Trying to determine if this is necessary and/or how to determine this. No glycol was in the system. It was operating as per ususal. Nicely plumbed Buderus boiler. Not old. 15 yrs. maybe? All copper plumbing. Zone valves are same age--6 matching Honeywell "Home" ZVs.
Only by getting your hands on the failed one could you make any judgment.
I'll bet the insurance company would like to see the failed valve also.Bob "hot rod" Rohr
True that hot_rod. It was a previous repair person who replaced the O-ring. I picked up a new zone valve at the supply house, took it apart and it looks fairly bullet proof as far as "how it could fail". I'm going to
suppose it was perhaps a "one off" situation, maybe valve wasn't assembled well enough from mfg. when installed.0
- 50 Industry Classes
