Possible oddball heat pump use
Daveinscranton
Member Posts: 148
I am attached to radiant in floor (masonry) pex heating. It was pretty cold here recently (like 5 degrees F and windy). My floor maxed out at 75.5 to keep the house at 71.
Some years ago, I heated the house as an experiment, with a 4500 watt electric hot water tank. It worked. Had to keep one eye on the weather channel. Lot of mass to heat up. Things got more comfortable (and cheaper) when I switched to a proper propane mod con boiler.
I am wondering about an air to water heat pump. 12-15,000 btu’s per hour for the shoulder seasons should do it.
Has anyone taken an air to air heat pump, stripped out the inside radiator coil, tossed it in a sealed tank (thereby making a heat exchanger), and hooked it up to hydronic heat?
I cannot find a small, air to water heat pump that would justify the expense.
My heat bills are fairly small here. It is more of a fascination/hobby. Still a serious question.
Thank you in advance.
You will actually want to get a Refrigerant to Water heat exchanger. Don't try to re-invent the wheel
https://aquasystemsinc.com/
https://midstatesrefrigsupply.com/brazed-plate-heat-exchanger/
https://www.supplyhouse.com/Kelvion-GBS400H-08-8-Plate-3-4-Thread-20-GPM-Heat-Exchanger-5-x-12 this one might be small enough for your needsEdward Young Retired
Thanks Ed!0
Just send me some Smidgens!
yeah, its called a heat pump water heater and they are available everywhere0
But a hpwh would need to be ducted outside. The 46 degree air discharge cannot be ignored in a small space.Bob "hot rod" Rohr
Living the hydronic dream0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
