Buderus gb142 quit
chief
Member Posts: 34
Hello, looking for some advise. My current set up-buderus GB142-30 multi-zone LP gas. Only filtering is a wye strainer. Feeding 5 cast iron radiators and one hot water coil on an air handling unit. System has run well for 15 years with normal maintenance/servicing.
Now starts the problems, multiple service calls for ignition issues. Can’t seem to get reliable ignition. Unit would work fine then require a reset. Service tech could not get unit to fire consistently. (I lost confidence in company doing service as well) Pump control board burned up, and the wiring harness connection has black arc tracking on it. I do not want to plug arc tracked connector on to a new pump board. Nor do I want to start replacing wiring harness on a 15 yr old buderus. I’m almost half way to a new boiler in parts costs.
Was going to replace buderus with a Lochinvar NKB110L heating only unit, but it will take 6 weeks to get that unit. At a local plumbing supply I found a laars MFTHW100 that looks comparable. They stock replacement parts as well. though I know the turn down on this laars model is only 5:1
The supplier is recommending running a water treatment agent in the system, the MC3 cleaner and treatment. I found a magnetic separator on supplyhouse the magnaclean pro 2 XP. Would this be a good idea introducing a cleaner/treatment into a system that has been operating well for 15 years? I do not mind investing if it will give me a better system. If I understand correctly this mag cleaner gives me a way to introduce the cleaner into the system as well.
Thank you for your time and input.
I don't think the cleaner will do anything to help with the issues you described. That boiler is pretty high maintenance and at the end of its life expectancy. I'm not a fan of aluminum boilers at all. I'd try to clean the fire side of the heat exchanger and replace the igniter and flame sensor and see if that helps. Order a new condensate tank as well, it will probably break when you take everything apart for cleaning. You will probably need to repeat the cleaning process several times before it gets clean
don't go with the NKB, go with the Lochinvar WHB. Better boiler. Used their firetubes since 1st one out in country. Been really reliable as long as cleaned annually. Also probably more available. Little more money but you will be happier.0
Talked ti a tech today that’s said gb units should have never of been certified for propane . He came over to check my unit that replaced my gb.
You need to have your tech while on site and call tech support to find the issue . (603) 552-1100
- 15.8K Strictly Steam
