Honeywell Power-pile VS8187A1203
parryj
Member Posts: 2
in Gas Heating
Hi All,
My boiler is starting intermittently. I traced the issue to a loose PP terminal on the power pile. I replaced the terminal on the wire end, but seems the terminal is loose in the terminal strip, as is the entire terminal strip loose to the unit. Are these power pile's serviceable (maybe an internal solder joint broke?)? Are these valves still available, or is there a suitable replacement that anyone know of?
Thanks Much!
JP - Winnipeg, MB Can
Thanks Much!
1
Yes I am sure you can cross it over if that particular valve is not made. Power pile valve are still used on gas fireplaces etc.0
The division of Honeywell that made those was spun off to a new company. Resideo.
https://en.wikipedia.org/wiki/Resideo
Might be this one,
https://www.supplyhouse.com/Resideo-VS820A1047-Standard-PowerPile-Millivolt-Combination-Gas-Valve-1-2-NPT-x-3-4-NPT
or it might not.
SupplyHouse has the specs and manuals on their site.
Be careful, mistakes can kill.
- 120 Geothermal
- 396 Solar
