Dunham 9a service?
guzzinerd
Member Posts: 453
Been cleaning up the dust on the pipes around the boiler. Repainting the return trap made me wonder... These things need any sort of periodic maintenance?
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Dave in Quad Cities, America
http://grandviewdavenport.com1 -
Thank you
- 50 Industry Classes
