Dunham 9a service?
guzzinerd
guzzinerd Member Posts: 423
edited January 2024 in Strictly Steam
Been cleaning up the dust on the pipes around the boiler.  Repainting the return trap made me wonder... These things need any sort of periodic maintenance?
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    https://youtu.be/j9FfGBXxDVE
    This link is helpful.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    guzzinerd
  • guzzinerd
    Thank you
