Honeywell T6 pro configured to Bosch IDS BOVA15 Heat Pump/Air Handler
tjcook727
Member Posts: 1
Just had a Bosch Split System heat pump installed and decided to switch to a smart thermostat in order to use the wifi function. However, it is asking me a bunch of question I do not know the answer to. Anyhelp would be appreciated.
Outdoor air sensor?
How many heating/cooling stages?
Fan operation heat-thermo or equip?
How many cooling/heat cycles per hour?
Indoor sensor-yes or no?
Indoor sensor type-10k or 20k?
Thermostat sensor selection?
Ventilation type-passive or fan only?
Vent method-percent or time?
Vent % on time?
Thanks
Vent % on time?
Thanks
These are onlu guesses based on a quick review of your instruction manual
Outdoor air sensor? NO
How many heating/cooling stages? 2 heat 1 cool
Fan operation heat-thermo or equip? thermo
How many cooling/heat cycles per hour? 4
Indoor sensor-yes or no? NO
Indoor sensor type-10k or 20k? N/A
Thermostat sensor selection? Thermostat
Ventilation type-passive or fan only? fan only
Vent method-percent or time? time
Vent % on time? zeroEdward Young Retired
- 169 Indoor-Air Quality
- 50 Industry Classes
