Can’t find the right aqua-stat I need
KamronS
Member Posts: 1
I have a very simple wood boiler set up that my step dad got all set up before he passed an it has an old aqua stat on it an it don’t work anymore and I got a new one but it’s on temp increase only. I need a temp decrease an one that can be wired to the solenoid so the damper door opens so I don’t have to go out and try to control the temp but I haven’t been able to find anything to help me online if anyone can here would be much appreciated
Post the model # and we can find one. In fact you can buy one that does both reverse acting (makes circuit on temp rise) and direct acting makes circuit on temp fall and Honeywell L4008A may work or call Supply House.com they can fix you up.0
Electronic controls are becoming more popular on wood burners. You have more adjustability and a temperature readout
You can extend the sensor lead alsoBob "hot rod" Rohr
Living the hydronic dream0
- 50 Industry Classes
