Bringing up cold water temperature
jfleming
Member Posts: 10
Tap temperature gets down into the low 40's where we live in the winter. For a variety of reasons, I'm looking at whether there's a solution that lets me:
- Have a higher baseline cold water temperature (e.g. 60 degrees) in the winter
- Doesn't increase the cold water temperature in the summertime (baseline temp is ~65)
Most thermostatics have a low range around 80- 85°.
What is the reason for bring the cold temperature up? An un-insulated galvanized well tank near the water heater would be another way to increase temperature. Let it warm from ambient temperature in the room.Bob "hot rod" Rohr
Living the hydronic dream2
