Coleman blower speed adjustment
HeatingHelp
Administrator Posts: 720
This discussion was created from comments split from: Coleman/Evcon Model DGAX070BDTA Blower speed adjustment.
Hello I think I am havig the same problem. However the manual does not show where the blower speed is controlled at. Mine is completely installed and I cannot take it back out. I where is this switch at on the blower?0
@somaerah_jo11 You should start your own discussion so folks here don't get confused. Try to reference this discussion in your discussion by copying this and pasting it in your own discussion https://forum.heatinghelp.com/discussion/194212/coleman-evcon-model-dgax070bdta-blower-speed-adjustment#
Also post your model number so we can look up the information needed to help you.Edward Young Retired
@somaerah_jo11, welcome to Heating Help! I've created a new discussion for you here to prevent confusion.
Thanks @EdTheHeaterMan.President
HeatingHelp.com0 -
@somaerah_jo11 your question is already answered in the other discussion if you have the same exact heater. Otherwise, if you provide the model number of your heater, or a picture of the rating plate that has the model and serial number, Or a clear picture of the wiring diagram that is usually found on the front door of your heater, then we can answer YOUR question based on YOUR heater.
- 116 Geothermal
- 15.8K Strictly Steam
