Coleman blower speed adjustment
HeatingHelp
HeatingHelp Administrator Posts: 721
This discussion was created from comments split from: Coleman/Evcon Model DGAX070BDTA Blower speed adjustment.
  • somaerah_jo11
    somaerah_jo11 Member Posts: 1
    Hello I think I am havig the same problem. However the manual does not show where the blower speed is controlled at. Mine is completely installed and I cannot take it back out. I where is this switch at on the blower?
    EdTheHeaterMan Member Posts: 12,005
    @somaerah_jo11 You should start your own discussion so folks here don't get confused. Try to reference this discussion in your discussion by copying this and pasting it in your own discussion https://forum.heatinghelp.com/discussion/194212/coleman-evcon-model-dgax070bdta-blower-speed-adjustment#
    Also post your model number so we can look up the information needed to help you.
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    @somaerah_jo11, welcome to Heating Help! I've created a new discussion for you here to prevent confusion.
    Thanks @EdTheHeaterMan.
    President
    HeatingHelp.com
    @somaerah_jo11 your question is already answered in the other discussion if you have the same exact heater. Otherwise, if you provide the model number of your heater, or a picture of the rating plate that has the model and serial number, Or a clear picture of the wiring diagram that is usually found on the front door of your heater, then we can answer YOUR question based on YOUR heater.
