Nozzle size
Scotth48
Member Posts: 2
in Oil Heating
Replacing my oil fired boiler with the same 4 section unit but a different brand. My house is about 1300 sq ft on each floor for a total of 2600. My old boiler came with a 1.25 nozzle and we used a 1.0 nozzle without any problems.
The new burner uses a 1.5 nozzle for a 200,000btu rating.
Can I go smaller on the nozzle size that would be more in line with the old boiler? 1.0-1.25 gallon.
Thanks.
Thanks.
Your new boiler is too big. How was it sized? If the house did fine burning 1 gallon per hour you don't need a boiler that can burn 1.5 unless you are planning a very large addition.
Steam boilers are sized by measuring the radiators. Hot water boilers are sized by calculating building heat loss.—
Bburd1 -
Wow. Are you heating the house with all the windows open? How was the boiler size determined? A 3 section would have been more than enough.
As far as the nozzle goes, the manufacturer usually specifies a few different firing rates depending on oil pump pressure and nozzle size. But you need to perform a combustion analysis after changing nozzles or else you can't be sure the burner is operating properly or safely.
I don't know of an additive that would keep the fuel from gelling down to -387°FHVACNUT said:...would be excellent if you lived on Pluto...
3 -
Just for comparison, my 4800 sq ft, 100 yr old condo building in the Boston area could be heated by a 1.0 gph input rate with margin to spare.
As others have said, unless you are somewhere above the Arctic Circle, you have way more capacity than you need.0 -
- 121 Chimneys & Flues
- 15.8K Strictly Steam
