GRUNDFOS pump noise
Zuki1
Member Posts: 8
It’s our first year in this house and it has a couple of GRUNDFOS pumps. The one on our crawl space seems to be making an odd noise, almost like a rubbing but it is not consistent. I have uploaded a video here
https://youtube.com/shorts/8jo4avPJv84?si=LPi5txW3Ud2y8cil
hopefully the video works. The sound isn’t as loud as the video makes it out to be. The hum is from a relay they is just out of the video.Just trying to figure out how I should go about fixing it.
Thanks,
Larry
Larry
Hi, Is the shaft of the motor in a horizontal position? If not, there may be air trapped in the pump. How hot is the pump? Should be very roughly the same temperature as the pumped fluid. If it's much hotter, the fluid isn't moving through enough to cool the pump.
Yours, Larry0 -
The shaft is horizontal. The pump seems
to be about the same temp as
the water. Thanks for asking0 -
Try loosening that screw a bit on the end to purge any air out of the shaft.
What is the pump used for?Bob "hot rod" Rohr
It’s for the radiant floor heat in the house. The boiler is out on the shop. I’ll see if there is any air.0
Very little water came out. When I have time, I’ll pull the cartridge out and inspect it.Maybe there is dirt/sediment around the impeller? I’ll order a replacement cartridge to have on hand in case this one is bad.0
There ain't no cartridge in a Grundfos pump. Sound like the pump is running dry. Remove the screw on the end of the pump with a screwdriver and see if water comes out. That is an old pump and may be worn bearings.0
I ended up replacing the cartridge. Cost was under half of a new pump. It is quieter now. I also rotated the body so wiring was on top.
Thanks for all the replies.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
