A haunted steam boiler funny story
Shore_heat2
Member Posts: 17
I was sent to a house fo a water leak in basement as I was outside the building trying to get in I heard the worst water hammer ever and hissing that sounded like a broken water pipe. I go in expecting the worst and found this. I later found out the other workers wouldn't go back because they thought it was haunted. The electrician said he even saw a couple radiators jump from the hammering the water was spraying out the radiator vents.
I looked at the first picture and said "where the hell is the return" Started thinking maybe it was counterflow.0
seriously no one is going to comment on the copper near boiler piping?? they replace the return lines with black iron pipe and leave the rest?0
you missed this part.CastIronGuy said:seriously no one is going to comment on the copper near boiler piping?? they replace the return lines with black iron pipe and leave the rest?
Shore_heat2 said:I know the boiler header shouldn't work the owner didn't want it redone but it somehow is working silently now.
2 -
So is the steam run to the right of the boiler counter flow?0
I thought the same thing, where is the return? Then, maybe it's a one pipe system and the skinny riser is the bottle neck.
This is so typical of modern day steam systems.0
So was the boiler there through the fire and the didn't replace it?0
Shore_heat2 said:I know the boiler header shouldn't work the owner didn't want it redone but it somehow is working silently now.0
Call this old steam boilerman what you will . Howz about a blowdown on that new return line? You know it's gonna be a sediment collector . Wthout maintenance there is no civilization .0
Yes the main had a plug in it I removed it and gallons of water poured out. I reused the plug on the return on the tee on floor by the wall for future servicing. I always try to think of the next guy because I'm usually that guy who was never thought about and end up cursing the first guys. The other main is short only serves two radiators and is set up as a counterflow main
1
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
