need info on skymark condenser
nytech28
Member Posts: 116
hay techs , I came across 2 luxaire airhandlers Models AP48CX21C, using a matching SKYMARK ceiling mounted condesor with ducted condensor discharge & suction, it's a 2 stage cooling crkt , I need to repalce only the condenser , any info if luxiare sells 2 indoor head to 1 ceiling mounted condesor .any info would be apreciated,am planning to keep airhandlers as they are in good coniditon will flush lines & add txv.
I don't know of any indoor air cooled condensers that can be ducted but I am sure someone makes one.
Are the two AHUs on 1 refrigerant circuit or are there two circuits?
Same as what you have google :"Engineered Air Solutions"0 -
2 separate circuits0
Google Engineered air solutions0
ok thanks0
- 123 Chimneys & Flues
