need info on skymark condenser
hay techs , I came across 2 luxaire airhandlers Models AP48CX21C, using a matching  SKYMARK ceiling mounted condesor with ducted condensor discharge & suction, it's a 2 stage cooling crkt  , I need to repalce only the condenser , any info if luxiare sells 2 indoor head to 1 ceiling mounted condesor .any info would be apreciated,am planning to keep airhandlers as they are in good coniditon will flush lines & add txv.
    EBEBRATT-Ed Member Posts: 19,729
    I don't know of any indoor air cooled condensers that can be ducted but I am sure someone makes one.
    Are the two AHUs on 1 refrigerant circuit or are there two circuits?
    Same as what you have google :"Engineered Air Solutions"
  • nytech28
    nytech28 Member Posts: 116
    2 separate circuits
    Google Engineered air solutions
  • nytech28
    ok thanks
