Completed Restoration of original American Radiator Rococo units
We wanted to restore them but don't have the equipment to do them here and did we want to pollute our home or property with lead paint flakes and dust. We considered chemical stripping and painting but ruled both out due to concerns about odors and off-gassing. We retained a local company to have the radiators sand blasted and powder coated.
Color is a subjective decision, and we wanted them to be an architectural feature but not loud or gaudy. Plus we wanted a color that we thought we could be happy with for the next several decades with no regard to design trends. When selecting colors, we looked at about 60 different variants of metallic pewter and silver. The color we chose was Starnight Silver PMB 5752 by Prismatic Powders. We ended up using 60 lbs. of it, which is pretty staggering in terms of scope.
We are delighted with the results. Aesthetically, they are incredible. There is no more lead flakes, and there are zero odors or off-gassing. I checked their heating performance before and after with my heat gun and it is identical. There are no leaks either.
We wouldn't change a thing about the process, materials or results.
Here are some photos which I thought you all might enjoy.
BEFORE:
DURING:
AFTER:
Wow. That is art.0
Very nice and thoughtful restoration.
I used to commute by train and would pass a scrap yard on the way. It had what I am calling "radiator mountain" - a huge pile of discarded radiators. Many worthy of discard and I'm sure some like these, worthy of a full restore and another 100 or so years of service. You'll not see a heat pump this beautiful ever.2
Amazing. Found one yesterday in a friend's storage unit and was tempted to make an offer but doesn't have any orifices at the top, except for a vent, that I need to hook up to my two pipe steam system.
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
I'm so jealous of you. I've been wanting to do this for years and seeing this might motivate me to do something about it next summer.
I'm torn between DIY and powder coating and I've read pros and cons for both. I'm curious, did you go with an outfit that has experience powdercoating steam radiators?0 -
In the restoration process, need you pay any attention to the seal between each section so as to renew it or not to disturb it? Or if it's not leaking leave well enough alone?0
@TheClevelandSteamer congratulations, looks like an excellent restoration job. Beautiful old radiator.
@robertantonucci these will have conical nipples with a metal-to-metal seal. In my opinion, if it's not leaking best to leave well alone. They hold up very well.0 -
Nice. I'm jealous. Many of my radiators need some love.
Wow what beauty! Appreciate you sharing because it helps me on a project I'm getting ready to do. Thanks
Very nice!!0
I have one of these radiators. Anyone know what thread type it uses for its fittings. Was told it was BSP, but NPT seems to thread in ok. Concerned about leakage if I use the wrong type.
@TheClevelandSteamer , do you remember the thread type?
thanks
NPT.
Nice restoration result! I believe the paint tag referenced in photo is' powdercoat" that many may find expensive. I had old paint on American Radiators removed by "soda blasting" or plastic like pellets vs sand blasting. They were repainted with a silver/gray ferrous metal paint ( No Primer) basically identical to your color in photos. That was 20 years ago and still fine as the day they were painted. I believe original coating on my radiators was lead paint as you suggest - even though it wasnt flaking and glad to be rid of it
Regards,
RTW
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
