If there no flow the heat won’t go.
Scottynot2hotti
Member Posts: 4
Just leaving a job for no heat in an apartment. Hydronic Baseboard heaters, zone valve and thermostat that controls the entire apartment. Two bedroom one bathroom.
The building is a three story walk up and this apartment is on the first floor but far away from the boiler room. I cannot get the heat to flow through the baseboards. I have checked the voltage at the thermostat (26v) the zone valve operation is good. I even checked the internals. The valve was replaced in 2020. There has been a hose bib installed and I am able to isolate the baseboards from the rest of the building. If I run water through the hose bib I get hot water but I cannot get the water to flow on its own. I am unable to access the boiler room as Strata has their own plumber. (Don’t get me started about Strata)
I suspect it could be the heating pump. But I have never had an issue like this on the first floor. Seems odd. Any ideas or other suggestions .
One pump for the entire building? Air or frozen pipes?Bob "hot rod" Rohr
No air or frozen pipes. I do have water flowing from the hose bib. Just no heat. I told them without access to the boiler room there isn’t much more I could do. It’s just eating at me that there might have been something else.0
