Weil McLain WM97+110 Gas-fired water boiler not thoroughly heating
Hot water wont circulate completely around my baseboard. The pipes are only hot for about 20 to 30 feet past the Area Control Valves.
skibbereen_
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Post pictures!
    Air bound, check valve stuck, new install?
  • CONFUZED
    CONFUZED Member Posts: 5
    Post pictures!
    I bled the lines at the beginning of the season when I got a check valve error and the fan kicks on once every min for about 30 seconds.
    EdTheHeaterMan Member Posts: 12,023
    edited November 2023
    CONFUZED said:
    Post pictures!
    Are you talking about the FAN in the WM boiler or another FAN in an air handler or something?
    The Combustion FAN in the WM boiler operating for only "30 seconds" sounds like a call for heat is interrupted before the system gets to ignite and complete the start up cycle.
    More details are necessary to understand the actual issue.
    You can post a video by sharing a youtube link or a facebook link
    Solid_Fuel_Man
  • CONFUZED
  • CONFUZED
    CONFUZED said:
    Post pictures!
    I ment to say Blower(#3 on the diagram) instead of fan.
    HVACNUT Member Posts: 7,403
    Show the boiler and system piping.
    How many zones?
    Indirect water heater?
  • Solid_Fuel_Man
    That is the worst sounding blower I've heard in awhile.
    Sounds like it's doing a prepurge, then trying to light burner....failing...then doing post purge.
    Does it light? Is there gas to the appliance?
