Heat sometimes won't start without running DHW first
ts004i
Member Posts: 9
in Gas Heating
I have a Lochinvar Noble combi system and occasionally the heat won't kick on unless I run the DHW first. It has happened a couple times overnight where the house temperature is well below where the thermostat is set but the boiler won't turn on unless I run a faucet with hot water for a few seconds.
Thoughts on what's going on? The boiler is about 3 years old and has been running fine.
Odd situation. Have you had a professional look at it?
Sounds like some sort of wiring or control issue that is intermittent. Does every start cycle for Heat need this DHW jump start?
Thanks, calling a professional today, it doesn’t seem to require DHW every time but it typically happens overnight, so maybe we are using DHW enough during the day that we don’t notice.0
