Hydro Separator Insulation
MarkC
Member Posts: 19
Hello, My system uses the separator linked below. Wondering if anyone knows if there are insulation jackets available? I have not been able to find one for this model. Looking for similar to what Caleffi offers for their separators. Any chance a Caleffi would reasonably fit? Are there third party/generic options available? Last option...fabricate one and if so suggested method/materials? Thx!!
https://www.fwwebb.com/product/PurePro/Hydro-Separator/HS1P/830268
What is the center to center dimension?Bob "hot rod" Rohr
Hi Bob,
Thanks for the pic!! Center to center is 8”. The separator’s ‘main cylinder’ is 3” OD, the supply/return collars are 1 3/4” OD, and the length is about 14”, excluding the collars for the air vent and drain.0 -
You could get some 1" or 1 1/2" "duct wrap" fiberglass insulation and put a couple of layers on that. Get the stuff with the silver-colored jacket and a roll of the aluminum tape they use for it. If you can find a source for a small amount. It comes in rools 4' wide x 50 feet long and you don't want to buy a whole roll. A HVAC contractor or a sheet metal shop may sell you a scrap piece.1
The part number is NA10801 for the insulation jacket.Bob "hot rod" Rohr
