1/4" black iron pigtail i.d. dimensions
Hvacdingus
Member Posts: 3
Hello, sorry for the oddball question. I have been looking around for the inner dimension of a 1/4" black iron pigtail and I cannot find it anywhere. Where I am we don't use steam for heating and we don't have one on hand that I could measure unfortunately. I would potentially like to use them for a Christmas gift if the dimensions work out.
Thanks for your time.
Corrected by JC_Jones0
dko said:black iron pipe is measured by ID. so a 1/4" nipple/pigtail is 1/4" ID. but ID is reduced at the loop due to bending
Sorry, I should have clarified what i.d. I was talking about.
I am talking about the i.d. of the loop itself. Not the pipe.
About 1-5/8" on the steel 1-1/2" on the brass.
Are you trying to slip it over a pipe?Bob "hot rod" Rohr
McMaster has 2d drawings and 3d models of them.Hvacdingus said:Hello, sorry for the oddball question. I have been looking around for the inner dimension of a 1/4" black iron pigtail and I cannot find it anywhere. Where I am we don't use steam for heating and we don't have one on hand that I could measure unfortunately. I would potentially like to use them for a Christmas gift if the dimensions work out.
https://www.mcmaster.com/products/pigtails/gauge-siphon-tubes-6/material~steel-1/
That statement is incorrect, and even though it's not the OP's question I think it's important to have proper information presented.dko said:black iron pipe is measured by ID. so a 1/4" nipple/pigtail is 1/4" ID.
The consistency in piping is the OD, the ID varies by schedule and almost none of the pipe actually has an ID that is the same as it's nominal size. If you look at the chart in the below link you will see all the different pipe ID's, and OD's and with few exceptions none of them match the nominal pipe sizing.
https://usaindustries.com/piping-isolation-testing-products/pipe-schedule-chart/
From what I see on McMaster's model it's 0.364" ID on the straight seamless steel pigtail.
- 50 Industry Classes
