gas pressure
Home
Member Posts: 1
Hi, we recently had a plumber doing work in our house to fix a gas leak. Our main gas line was turned off by the gas company due to the leak. In order to test the pipes, he applied 10 psi against our appliances. My question is can this damage the appliances (furnace, oven, water boiler) if done for a short time? And he found multiple leaks after fixing the first one- can that have been caused by applying more pressure than the pipes can handle during his testing?
Thank you!
Thank you!
1
You'll know soon enough! Have a sharp Appliance repairman (a dying breed) to check them. Mad Dog 🐕0
- 117 Geothermal
