What's this buzzing sound? Coming from a baseboard steam convector.
ariccio
Member Posts: 83
Pretty straightforward!
This is in a 1961 NYC multifamily apartment building with a low pressure steam vacuum system. Using baseboard convectors and classic thermostatic steam traps.
This sound occurs anytime there's heat. Seemingly more when there's more heat.
I can't upload it, the m4a is not accepted, I will try to share a link in a reply?
The sound did not improve after replacing the trap. Using a Mechanic's stethoscope, I can tell it's either coming directly from the trap, or right next to it.
https://drive.google.com/file/d/1GTXrHFAVi60tMqGYG19UDJYV48fWEp6B/view?usp=drivesdk0 -
What steam pressure is the system running?—
Bburd0 -
No idea why I missed this! Well, probably has something to do with having 47 different social media accounts and apps.
I have this picture from around the time of the post. I can't make out the numbers, but it does look like this on the very low end of the gauge 🤦♂️🤦♂️
This appeared to be a vacuum pump. Not 100% sure, but, well, the gauge showed a vacuum.
(sorry to multi-post in a row, something about uploading images messes up the edit box for me here)
Incidentally, the co-op board has decided they're moving forward with a fancy boiler replacement without any steam trap replacement and maintenance program. I'm certainly waiting to see how that goes! I suspect I will be able to "I told you so!" A few people.1
- 50 Industry Classes
