How to tell if Steam Trap is Bad?
Check temperature differential between inlet and outlet. It can be tricky at different points during the heating cycle but there should generally be a 10° difference.
I use a sonic measuring tool that listens to the trap opening and closing. Or not.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
The cheapest ($350) FLIR gun has been my best tool for this.
Especially if you can follow the return pipe for a foot or 2 away from the trap.
BTW, this is for rad traps not F&T.
Has anyone tried the doctor stethoscope on the traps for the sound?0 -
A mechanic's stethoscope seems to work as well as the super expensive ultrasonic sensor that I've read are used industrially.0
- 117 Geothermal
