GAS FURNANCE CLEAN OUT
chrisrhit
chrisrhit Member Posts: 6
Hello,
In the attached pics, if I put a camera in the clean out tee what should I see? How far in from the clean out tee should I be able to get it? It appears that I have a clay liner chimney and a 1950-1960 american standard heater. thx chris coll
  • Intplm.
    Intplm. Member Posts: 2,800
    Ideally, you should be able to see daylight through the top of the chimney.
  • chrisrhit
    ok cool thx! guess i will check during the day instead of night time🤦🏼‍♀️
    mattmia2 Member Posts: 15,302
    That is a breach from an appliance that is no longer there, maybe a shorter water heater or an incinerator or an old boiler.
