Trickle Flow through Noritz NRCB199DV
AmosCall
AmosCall Member Posts: 1
I am working on an installation for a NRCB199DV boiler.
When I connect the water hose to my system to fill/ bleed out air, I get decent flow, but only when I bypass the boiler. When I run the same setup through the boiler it slows down to a trickle.
I occasionally get error code 54, or the system will heat up but water will not push through. I have 2 zones fed by Grudfos pumps which are running, and the system is calling for heat from the boiler.
When The boiler is first turned on I get a good flow as the system goes through it's start-up routine, but then stops.
Any thoughts on why the boiler is the bottleneck here?
  • GGross
    GGross Member Posts: 1,845
    Looks like a combi. Perhaps a diverting valve is in the wrong positions when you are trying to purge?
