Loop design
matthewdice
Member Posts: 1
Like series vs parallel? It depends on the system, but generally speaking, when piped in series each emitter will get cooler water than the previous emitter which reduces the BTU output as you go further down the line. With parallel, each emitter gets the same water temp.0
