Wrong LWCO, P Trol all blocked with Splooge
Mad Dog_2
Member Posts: 8,681
This is an Old Burnham Gas Steamer with Powerpile (millivolt) system. Years ago they changed the LWCO, but put in a #67.
I replaced with the #67 G, changed out all the boiler drains (100% packed with Mud), added a Gorton #2 (The old tee was plugged...no main vent!), raised up the P Trol and added a 3 PSI Steam Guage, new Relief valve. LWCO, Guage glass cocks 100% blocked...Mad Dog 🐕0 -
Don't let the belly fool ya...Like a Mouse 🐁, I can flatten myself to fit in any spot! This was under a stairs...Very tight. Kept getting dinged in the scull by nails sticking down..ha ha 😂 🤣 😆. Mad Dog1
gotta love these brand new Yellow Brass Pigtails...Bent right out of the box! Mad Dog..
What a mess. Hope you were able to save it.
The old one a black pigtail right on top of the LWCO. No surprise it plugged.
Is a 67 G the same as a normal 67 it just has a millivolt rated switch correct?0 -
Boilers fine...5 contractors came in...you need a new Boiler!! The #67 G is seperate unit from a #67. I believe the Millivolt switch works better with Powerpile or the #67 might not even break in a low water event. A better Electric person can splain that, but thats what I was Taught. Mad Dog 🐕0
Testing across contacts with millivolts helps in diagnosing losses in the mv control circuit. Starting at the gas valve where powerpiile connects you can test the whole control circuit there by putting test lead on the side of power pile that also has a wire going out to controls and the other meter lead on the wire coming back from control circuit. This will give you cumulative loss of all controls in circuit. If you are are losing say more than 50 mv or so. Start checking across each control contacts to see which one or multiple are losing too much.
Nothing like ample room to service a boiler...no wonder no one maintains them. Mad Dog 🐕1
The water heater looks newer than the boiler- I'd fault whoever put that unit in.
Consulting1 -
The HO is a retired Airplane ✈ mechanic. He did everything himself and that's also his little shop down there.with all his Snap On tool cases and on the right The Missus stacked her crafts...As plumbers, "Heaters" and steamfitters that we are, I always do.my my best to Elbow my way 💪 some extra room...G.C.s, Engineers, Architects and H.O.s do their best to contain us in the the smallest possible foot print. I point out that this will lead to Less or no maintenance, premature failure AND much more expensive service calls in the future if a 10 minute repair takes an hour because you DIE accessing it! Mad Dog 🐕0
The Airplane mechanic loved how I set the Guages up for him. Mad Dog 🐕2
- 87.7K THE MAIN WALL
- 128 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
