Shut off
kjohnson
Member Posts: 2
in Gas Heating
Our 2year old HZ311 furnace, in the heat on mode, has the burners light and then quickly turn off. Happens about three times and then after five minutes or so, repeats this process.
2 zones used (1&3). Lights were on. Purge light is steady yellow. Heat light on red.0
Hi, @kjohnson , I think some photos would help. It sounds like you have a boiler rather than a furnace. What make is it? 🤔
Yours, Larry0 -
The only HZ311 I could find is not a Furnace or a Boiler
One Pipe System0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
