Shut off
kjohnson
kjohnson Member Posts: 2
Our 2year old HZ311 furnace, in the heat on mode, has the burners light and then quickly turn off. Happens about three times and then after five minutes or so, repeats this process.
  • kjohnson
    2 zones used (1&3). Lights were on. Purge light is steady yellow. Heat light on red.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,094
    Hi, @kjohnson , I think some photos would help. It sounds like you have a boiler rather than a furnace. What make is it? 🤔
    Yours, Larry
    109A_5 Member Posts: 3,996
    The only HZ311 I could find is not a Furnace or a Boiler
