In floor heat
Hvacdoc
Member Posts: 2
I have a Navien NCB 240 with in floor heat my brother added on a living space and extra work area to the barn/shop. What to add a 2nd Navien to make up the needed btu since tue ncb is 1.5 yrs old since install but has not run. So it’s brand new. (Just spray foam the barn this summer). Navien says I can cascade a Navien NPE. Water heater on to it. But can’t find no info of that is correct that I can do it. or how to pipe it properly.
ExactlyHot_water_fan said:Why do you think you need a second? That’s a huge boiler!
Unless "my brother added on a living space and extra work area to the barn/shop." is a really really big addition.Edward Young Retired
Sounds like he has a combi boiler and wants to add a tankless WH to the set up. Some MFG allow you to pipe these in a manner that if the combi cant handle the DHW supply the Tankless will kick in. If navien says its doable you should contact their tech dept and or a contractor in your area who is very familiar w/ them.
You need to remember the combi 240 is not 240,000 btu. It’s only 199,999 for DHW. heating is only 130,000 btu.0
