Honeywell PowerTrack MZV520-RP zone valve actuators for barter
Sol_Brother
Member Posts: 34
A customer was fed up with his old zone valves and had me replace them all with Taco Zone Sentrys, so I have 13 actuators and a couple of valves available. As far as I know these are no longer manufactured or available for sale. Some of mine are new, others removed working but I am not guaranteeing them. I am interested in hearing from you if you have customers with Honeywell valves and want to propose a swap for other hydronic gear (although not boiler-related as I use mostly Chiltrix heat pumps and solar.)
By the way, these look and operate exactly like ones I found on an old brass Wirsbo manifold, but the thread size is different so I could not find a way to use them on that.
Tom Wills
tom@solarconsultants.com
Tom Wills
Sol Brother
good morning, do you still have these actuators, if so I am interested in at least a few of them
thank you0 -
Yes, I do still have them.Sol Brother0
Scooterbob, last chance to claim any. I have two actuators left that test good and two whose motors work but end switches do not close, plus a few valves. Another person wrote asking for some but I told him you have first dibs. You can write me directly: tom@solarconsultants.comSol Brother0
All of these actuators have gone off to new homes.Sol Brother0
- 123 Chimneys & Flues
