1897 American Radiator Catalogue
bergensteamguy
Member Posts: 64
I am looking through the online catalog for American Radiator Company (1897). I am trying to determine the EDR for my radiators. I cannot read the catalog. Not sure if its my computer or not. Does any know the square footage (EDR) for the Italian Flue Steam Radiator. It is approximately 38 inches high. One is 5 sections, 7 sections, and 8 sections.
Should be 38" in first column. 7sqft per section. 5section = 35sqft 7 section = 49sqft and 8 section = 56sqft. Agree, not easy to read.0
Hi @dabrakeman, It appears the 1st column is 45inches... Am I mistaken?0
Beautiful radiators BTW. You should post a picture of what you have!0
@dabrakeman , yes they are. very ornate. thank you. i will try and post a picture0
Looks to me like 38", 32", 26" and 20".bergensteamguy said:Hi @dabrakeman, It appears the 1st column is 45inches... Am I mistaken?
@bergensteamguy , 5 sections is 35 square feet, 7 is 49, 8 is 56. 7 square feet per section.
And do post some pics of these beauties.All Steamed Up, Inc.
Consulting0 -
Thank you all! Appreciate it0
Per popular demand, I uploaded a picture of my radiators. These are the Italian Flue steam radiators. Made by the American Radiator Company. I only know this because @Steamhead was kind enough to upload the 1897 catalog from The American Radiator Company.
Quite the treasures. Did you have them recently refinished? Hope your system is performing as good as it looks.0
They're beauties. but those are rather large vents- are your main vents big enough?All Steamed Up, Inc.
Consulting0 -
Hi @dabrakeman, Thank you! I did refinish the one where there is an outlet in the picture. I stripped it down to the bear cast iron using a brush and paint remover. I used an oil-based paint from rustoleum. I believe it was called antique gray.dabrakeman said:Quite the treasures. Did you have them recently refinished? Hope your system is performing as good as it looks.
Hi @Steamhead, I used the Gerry Gill method to size the venting, and I sized the vent according to the radiator size. The one with the outlet in view is only a Gorton 5, because it is in the room with the thermostat. The other one is a heat timer since it is the largest radiator. I had a Gorton #D on there, but it seemed it vented to slow and took long to heat up.. As for the mains... The longest run I have is 50ft of 2inch pipe. I have 3 x Gorton #2s for venting. The other branch of the main (its splits off in two) is only about 8 feet. I have 1 gorton #d venting that main. If you have any recommendations, I am certainly open to feedback.Steamhead said:They're beauties. but those are rather large vents- are your main vents big enough?
- 50 Industry Classes
