new gas condensing boiler
soot5bic
soot5bic Member Posts: 11
just installed new viesmann 200 gas condensing hot water boiler. System is incredibly efficient and am very happy with it. Am wondering however, if the system [zones and heat exchanger] should be purged and flushed on a regular basis. Have seen other heat exchangers plug up over time and wondering if annual or longer flushing along with regular cleaning is advisable. Am not sure if flushing with fresh water is a good idea. Appreciate thoughts.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,546
    Glad you're Happy..Viessman is The Gold Standard.  What is the Boiler connected to  system-wise?  Steel & Iron fittings? Copper baseboard?  That's going to tell you alot. We'd love to see some pictures...Mad Dog 🐕
    hot_rod Member Posts: 27,446
    No need or reason to flush. Hopefully good water was used to fill. The manual has the water spec.
    GGross
  • soot5bic
    system is all copper piping along with copper baseboard, supposedly thoroughly flushed and purged upon initial install. also has purpro hydroseperator installed. standard town water [treated] used.
  • neilc
    neilc Member Posts: 3,174
    is the system quiet?
    you don't hear water rushing around the house, correct?
    if you do then there's still air inside,
    post pictures, general wide shot of boiler, circ(s), expansion tank, zone valves,
    all in one shot, maybe from a couple angles,
    we'll see what we see,
    known to beat dead horses
  • soot5bic
    system quiet as can be. lowered pump speed to 70% and 80% for zones and hot water. just a quiet hum when system is running. can't tell if system is running unless you are next to the boiler.
  • neilc
    success
