Caleffi stencil templates??
OldawgBryant
Member Posts: 69
Can't seem to find the free stencil templates for visio... Caleffi website pages has error. Does anyone have any?
Also Idronics vol #7 page has error...
www.old.caleffi.comBob "hot rod" Rohr
@hot_rod server not found...0
Italy built a new website, but not everything moved over
old.caleffi.com will work, but I still could not find the stencils. Ill check with the webmaster tomorrow. SorryBob "hot rod" Rohr
thank you sir!0
TY @hot_rod . I can use these as well.0
EBEBRATT-Ed said:TY @hot_rod . I can use these as well.
on a Mac there are some programs you can add that will run it
Some of the other CAD programs will run those files also
use the link two posts up and see if they load into your computer
my Mac told me file not supportedBob "hot rod" Rohr
@hot_rod
Yes I have Visio. Not an expert with it but have been using it for years. Already downloaded and they work fine. TY
Much appreciated1
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
