Snef hole in the wild (good job HTP)
Teemok
Teemok Member, Email Confirmation Posts: 757
A little on the low side for me. I'm sure there's a logic to it's placement. Probably not mixing down the hot outlet with cold if it's faced the wrong way. 7 gallons gets siphoned out before the snef hole comes into play.
    hot_rod Member Posts: 27,147
    What’s the oval shaped opening? In the floor of the van?
  • Teemok
    That's the exterior flue opening of a Rinnai tank-less on it's back. :)
