Weil-Mclain 78-80 series leaking
Bigj59
Member Posts: 2
I have this Weil Mclain 78-80 series boiler, with the bad castings. Under operating conditions at least six of the sections are leaking (the other four sections have been previously replaced). The relief valves are set for 30 PSI, and were tested at 45 PSI which showed no leakage.
What would cause it to leak when operating but not under test.
Normal operating pressure is 20 PSI @ 180F
Sometimes they leak when hot, sometimes when there cold. Did you test both ways? I've also seen them leak into the combustion chamber (not necessarily outside where the cabinet goes).0
Unless the sections are actually cracked or corroded so the gaskets will not seal then the sections should be ok. Unless the pins are damaged from flue gas condensation0
