Acceptable number of PEX splices?
If you have PEX A you should be able to remove any kink with a heat gun or hair dryer.
https://www.youtube.com/watch?v=JRxhIxg2g94 Edward Young Retired
2 -
Sorry, should have stated up front, PEX B.
Really? A half dozen? Even I should be able to get under six for a 250' loop.mattmia2 said:Pex A with propex as many as you are willing to pay for. With other fittings that reduce the diameter many could start to be a problem. A half dozen or so aren't likely to be an issue.
Are you installing the pex yourself? Its kind of hard to kink it with two guys...Mad Dog 🐕0
Yeah, it's just me. The stuff is really frustrating. It's weird how something so rigid can get so tangled.Mad Dog_2 said:Are you installing the pex yourself?
This is reassuring.GroundUp said:2 inches of diameter reduction for a crimp coupling is not even noticeable in a 250ft loop. Obviously fewer is better, but a few per loop isn't going to hurt anything from a flow perspective.
This is concerning.GroundUp said:They are potential leak points, however.
So far, I've only run loops in the basement joists. A leak there is easily addressable. Perhaps, to avoid the kinks, I'll get some help when I move to the next floor where leaks would be much harder to fix.
If you can warm it up a bit that helps too.0
I find holding the loops in one arm and keep Flipping it to keep the natural way it wants to roll out going in the same direction. Not easy to do yourself but but this works for me. Mad Dog 🐕1
I have found that pex is great when it comes to kinking. You do not always have to heat it or "splice" it.
One thing that you can do is to simply straighten the pipe and let the pex reclaim its memory. That's what's great about pex, it has memory. It will return to its original shape.
If you don't want to wait for it to return to its original form, you can use a pair of pliers to reform the tubing.1 -
Or at least pick up the coil and unroll it to get a length to work with, don't pull it off the side.Mad Dog_2 said:I find holding the loops in one arm and keep Flipping it to keep the natural way it wants to roll out going in the same direction. Not easy to do yourself but but this works for me. Mad Dog 🐕
I've had a kinked piece of 1/2" pex sitting on my shelf for close to 10 years now and it's still kinked. Are you sure?Intplm. said:I have found that pex is great when it comes to kinking. You do not always have to heat it or "splice" it.
If you don't want to wait for it to return to its original form, you can use a pair of pliers to reform the tubing.0 -
I am sure. So if it doesn't find its memory, something else is afoot. Use the other methods as described previously.GroundUp said:
