HW Tanks: Burnham Alliance LT vs Vaughn Featherweight
seized123
Member Posts: 432
Any opinions re these plastic tanks? I submitted a query via their website (checking the “homeowner” tab) to Vaughn a week ago about the Featherweight and haven’t heard back which makes me doubt customer service a bit. But anyway, opinions or experiences welcome. Both offer an optional lifetime warranty, FWIW.
Also, Weil McLain’s Aqua-Pro has a “non-metallic tank,” but so far I haven’t found any more details about what that means. I have decided on plastic because we have high chlorides with no prospect of mitigating that anytime soon. Rheem has plastic tanks as Larry W. and others helpfully suggested on another thread, but I think they don’t have indirects, which I think I would prefer (for vague-ish reasons).
I have not installed any of the plastic or composite indirects.
Standard glass lined indirects work well in almost all water conditions.
Most all gas and electric tanks are glass lined. Probably all your neighborsBob "hot rod" Rohr
Hi @seized123 , I'm thinking it depends on what you are trying to accomplish. Also, water quality plays into any answer. So, what are you up to? 😇
Yours, Larry1 -
@Larry Weingarten, one word: chlorides. It’d be nice to treat them but meanwhile we’ve been through many hw heaters, maybe 3 SS ones in 6-10 years, more before that.0
Hi, Glass lined can work as long as you use powered, or impressed current anodes. Sacrificial anodes may last only six months and cause odor and gas problems. I only have experience with the Marathon tanks, so can't suggest anything other than to carefully read the warranties on other plastic tanks and count the loopholes 😏
Yours, Larry0 -
Yup, will definitely look for loopholes.0
Ok, so ha, so after a look at the specs and manuals and looking at a few threads it looks like these might be basically the same heaters with different names, apparently that’s common, didn’t know that. Energy Kinetics has a High-Flow plastic heater that looks similar too … Wonder who actually makes these things.0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
