Seeking someone to pour gypcrete in NW Arkansas
HeatingHelp
Administrator Posts: 721
This discussion was created from comments split from: Help with Design - Earth Floor over radiant hydronic.
i am seeking someone to pour gypcrete in nw arkansas new build0
I installed a few systems in the Harrison, Arkansas area, and a number of gyp systems in SW Missouri.
A Maxxon installer called Clarks Concrete from somewhere around Lake of the Ozark, Mo pumped them.
clarksconcrete.com
Does it need to be gypcrete? A basic concrete grout pump that they pull behind a pickup can pump pea gravel mixes. I've poured pea gravel concrete as thin as 1-1/2"Bob "hot rod" Rohr
Living the hydronic dream1 -
@goodend, I've moved your discussion here to prevent confusion with the other discussion. Thanks.
President
HeatingHelp.com0 -
Plumbing wise I have worked in 6 states, that I can remember. A few weeks on the base in GTMOMad Dog_2 said:Geez Hot Rod..what State HAVEN'T you worked in???ย ๐ย
16 years with Caleffi as a trainer Ive been to every state!
It has been a great ride so far๐Bob "hot rod" Rohr
Did you do any exploring when you were there? I drove the whole base did as much hiking around and picture taking as the MP felt comfortable withMad Dog_2 said:You worked at Gitmo too?ย Super Cool..Mad Dog ๐ย
They started following me around as I got to nosey.
All the contractor lead people were there with Tradesmen International. Tax free income if you signed on for 18 months.
The head plumber from Rochester signed on just to have access to the snorkeling for two years. Another contractor wanted to fish the bay.
They have a nice marina where you can rent all sorts of boats.
Here is one of the locals that I met, looking for some fresh reading material, I suspected.Bob "hot rod" Rohr
Living the hydronic dream3 -
Ha ha.ย New York State Guard, not a Marine...never been to Cuba. I meant that you ALSO worked there? I'm hoping they DO finally open up Cuba... Mad Dog0
- 117 Geothermal
