Seeking someone to pour gypcrete in NW Arkansas
HeatingHelp
HeatingHelp Administrator Posts: 707
This discussion was created from comments split from: Help with Design - Earth Floor over radiant hydronic.
  • goodend
    goodend Member Posts: 1
    i am seeking someone to pour gypcrete in nw arkansas new build
    hot_rod Member Posts: 25,384
    I installed a few systems in the Harrison, Arkansas area, and a number of gyp systems in SW Missouri.
    A Maxxon installer called Clarks Concrete from somewhere around Lake of the Ozark, Mo pumped them.
    clarksconcrete.com
    Does it need to be gypcrete? A basic concrete grout pump that they pull behind a pickup can pump pea gravel mixes. I've poured pea gravel concrete as thin as 1-1/2"
    Mad Dog_2
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,360
    @goodend, I've moved your discussion here to prevent confusion with the other discussion. Thanks.
    President
    HeatingHelp.com
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,274
    Geez Hot Rod..what State HAVEN'T you worked in???ย  ๐Ÿ˜‚ย
    Plumbing wise I have worked in 6 states, that I can remember. A few weeks on the base in GTMO
    16 years with Caleffi as a trainer Ive been to every state!
    It has been a great ride so far๐Ÿšš
    Mad Dog_2
  • Mad Dog_2
    You worked at Gitmo too?ย  Super Cool..Mad Dog ๐Ÿ•ย
    Did you do any exploring when you were there? I drove the whole base did as much hiking around and picture taking as the MP felt comfortable with :) They started following me around as I got to nosey.
    All the contractor lead people were there with Tradesmen International. Tax free income if you signed on for 18 months.
    The head plumber from Rochester signed on just to have access to the snorkeling for two years. Another contractor wanted to fish the bay.
    They have a nice marina where you can rent all sorts of boats.
    Here is one of the locals that I met, looking for some fresh reading material, I suspected.
    JUGHNEPC7060Mad Dog_2
  • Mad Dog_2
    Ha ha.ย  New York State Guard, not a Marine...never been to Cuba. I meant that you ALSO worked there? I'm hoping they DO finally open up Cuba... Mad Dog
